need some wireless network help
tunatime
Well...OK
so my boat shed was broken in to last week and im going to be putting up 2 1080p cameras. The thing is my boat shed is about 300ft away form my house and i was wondering what is the best way to set up a wireless network form the house to the shed. it looks like i can just get two routers and set them up in bridge mode is that correct? Or is there a better and easy way to get this done.
do you have any suggestions on routers and antennas that would work good? and whit routers whit more then 1 antenna do i need to get 3 antennas for each router? or should i just go whit a single antenna g router? would a g network be abaly to handle the bandwidth of the cameras or would it be better to go whit a N network and just put 3 antennas for each router?
