Need Some USB Help
Verown
Hello, i need a little help here im not to sure what to do. I recently reformatted my computer and i was pretty sure that i installed all of the most up to date drivers for my computer but what i don't understand is when my computer suspends, or i simply just turn off the monitor then back on i get this message. i have 4 usb ports on the back of the mother board and two up front on the case along with a few on the side of my monitor. i don't know if this is a driver thing, or something i have hooked up wrong inside.
the usb device can perform faster if you connect it to a high speed usb 2.0 port, and here is the list that pops up if i double click it.
I would like some more info on this too, i too experience this , usually the first week of the installation and after that it goes OK , weird
Are you running the dell lcds with the built in usb hubs on the side ? If so, they include a driver cd which came with it. Maybe that might help, my logic being that monitor turns off/on and the O/S might be redetecting the usb ports on the monitor.
yeah im using a dell sp 2001 flat panel, but i don't use the usb ports on the monitor just the one that connect it to the computer, is that the port the computer is talking about? because im just worried about it effecting my mouse.
It looks like your USB 2 drivers aren't loaded. You should see an "enhanced USB host controller" entry under device manager for USB 2. Try the update driver wizard and let it search the net for a driver. With luck it will download the USB 2 driver from Microsoft. They are supposed to be installed with sp1 or sp2, can't remember which one. It's never worked for me and I always end up installing the USB 2 drivers manually.
nice, ran it, installed em, problem gone, dunno why i didn't think about that in the first place but thanks
That's the thing about it. They were working and you had no yellow ! in device manager so it's not really obvious that it's a missing driver. I bet you remember next time you have to reinstall XP though. :)
just reading the other day and you can attach 127 usb peripherals on one usb controller by daisy chaining them , amazing or what.
yea but you are limited in the amount of current 1 usb port can draw which would prob run out by device 3 (jk). but it would never reach 127.
I used to get this error however i made it so it would not appear and as now you have come up with a cure anyway i can get back to teh settings lol cheers
If you use powered hubs and current draw isn't a problem.
