So I've got 3 computers in a van with 3 seperate wall mounts for the keyboard/mice connections. Currently they are PS/2 connections but I'm wanting to go with USB. My reasoning being that (1.) the new keyboards/mice are not all being recognized unless plugged directly into the computer via USB, (2.) occasionally the person using the computer will bump the keyboard/mouse connection and when reconnecting the cable it will not always come back online without a system reboot. I've been doing a little research on USB extension cables and it seems that the maximum length that you can run is 5m (16ft). All of the cableing is going through about 2in wide duct along the van wall.
After measuring distance herein lies my problem:
Computer 1 is roughly 15.6ft from the keyboard/mouse wall mount
CPU 2 is 26.2ft
CPU 3 is 37.5ft
I was originally going to just run a long enough extension cable or daisy chain but then did the research on limitations. Is there a way of working this that I don't know? Perhaps an amplified USB extension cable...if there is one?
CPU 2 is 26.2ft
CPU 3 is 37.5ft
