About a month ago I had a Zalman case that bugged out on me. By bugged out, I mean the top panel with the fan controller, usb ports, and temp readout had problems and started flickering, fans died, and one day when I came home one of the fan controllers had started melting... It was all one piece and couldn't really be replaced without dremel work so I just replaced the case entirely.
The problem I am having is now I am getting a constant Connect and Disconnect of a USB device which shows up as "Unknown USB Device (Device Descriptor Request Failed)." This Connects and promptly Disconnects about every 1-2 seconds. After 5-6 hours it stops, but if I shut down the computer, or it updates and reboots, it comes back.
I have gone through my power settings and disabled usb selective suspending. I have also, to my hilarity and confusion disconnected EVERY USB device from my computer and even gone so far as to disconnect the case USB cables from the motherboard headers with no change.
I have THIS motherboard with a 6800k and 48gb ram. No other problems noted.
http://prntscr.com/erk1vp
