Need some suggestions
Looking to upgrade my current system (athlonXP 1.6ghz)- namely the mobo, CPU, and RAM. I also am on a budget. I'd say about 300-350 dollars and can go a bit higher if so.
What would be the best setup I could get that would last me a pretty good time before upgrading again.
- When I was browsing Newgg and looking at the operating frequencies- the AMDs that were 3.0ghz+ had operating frequencies from around 2.0ghz. The Intels had the same frequencies as showed in their titles. Why is it that?
How much RAM are you looking to buy, and what do you have at the moment? For CPU definately go with a s754 AMD64 newcastle core...maybe a 3000 or 3200+. A cheap mobo for the s754 is the chaintech VNF3-250 which has good onboard sound, but I hear the DFI-lanparty is a good choice as well (think it's around 120 or so). The chiantech + 3000+ newcastle will probably be around $250 or so.
As far as the 3000+ 2.0ghz AMD being comperable to the P4 3.0hz chip...The AMD does more per clock cycle but runs at a slower frequency while the P4's do less per clock cycle but run faster. I hate to bite from somebody else analogy, but it was a good one.
Think of AMD as a dumptruck and P4 as a pickup. The dumptruck is slower but can haul more so it takes less trips. The pickup is faster, but can haul less, so it takes more trips.
I currently have:
Athlon XP 1.6ghz
Epox 8kha+
512mb RAM pc 2100
ATI Radeon 9800 pro 256 megs
Hercules GTXP
Bought the 9800 because I planned on upgrading the CPU/mobo soon.
As for RAM, 512megs sounds good enough for me.
