need some speakers
EchoMatrix
I got a little money to spend and right now I have some velodyne's i got on sale a while back.
Whats some good speakers that I can use with my Pioneer DSX-D914? CHT SWV are the speakers I have now. Not too big, maybe something that can sit on my desk 1 square ft at the max. ANything I should consiter? change about my possible criterion?
thanks all
might be a little big but
http://www.behringer.com/B2030P/index.cfm?lang=ENG
$190MSRP for a pair of passive studio monitor. ive got the big brothers of these as rear in my surround system. love em. got them really cheap too like 40% below MSRP (helps when you work for a pro sound company no markup for me WOOT!)
is there a site on the internet that allows someone to compare speakers and their specs? Those look temping though.
I know I need to look for Ohms, freq range, what else?
also this thing sits right in front of me. should I keep it small when its right next to me?
I saw the back of those bose. I thought I was going to cry... no bananaplug interface
what bose?
the behringer ones i pointed out are designed as reference speakers IE flat responce
i believe the smaller of the two models is ~75hz-20Khz -+3db
behringer.com has specs white papers, pics, dimensions etc etc
smaller then that i would recommend the Tannoy i5aw
http://www.tannoy.com/i5AW
the 301 and 201 i believe. saw the back of the at best buy and it made me cry... WORST connection possible for those speakers, the type you find on those cheap ones at wal mart
bose is fo rlack of a better word... weird
i have 4 of their older PRO AUDIO 802-II loudspeakers
i use two modded (added a supertweeter) ones in my HT system. they are very large though but have a very cool soundstage. very wide and transparent. the high end isnt laser like
I still recommend the behringer, or tannoy
ended up getting
Polk Audio Monitor 40 BK Pair Books
got dual mid range drivers and OK reviews. I dunno, it better just be better than bose at least in connection type
