Heya folders
So, first off this will be a server + devel machine for getting work done, reliability is critical. It will be running Windows 2003 Enterprise Server (32bit for now, but 64bit later), with server functions and all the devel tools known to man. I dont upgrade often (using a Duron 700 now), so this will probably be my main work/server machine for 3-4 years. No mods or overclocking will be done.
Here is my proposed spec:
I'll just remove the 6-in-1 reader unless they come out with an "L" model shortly, I dont have a digital camera anyway. As far as I've read, I'll only need an extra SATA cable, but all other cables should be included. The V2 should have fixed all the issues that the earlier model had. Installs require the 6-in-1 removed, and a floppy in with the SATA drivers (what idiot decided that was a smart plan), but otherwise should be smooth in theory.
Am I missing anything? Pools of molten metal in my future? Which RAM will be good and solid?
- Shuttle SN85G4V2
- Athlon 64 3200+
- 2GB DDR (brand suggestions?) for VirtualPC'ing XP/98/Linux/FBSD
- WD Raptor SATA 74GB x 2 in RAID1 (no more backups)
- ATI X800 Pro - for BrookGPU devel, more speed, but only 24bit, and for Lineage 2 (gotta have _some_ fun)
- and my current Pioneer DVR-A07 burner
