Need some recommendations on a gaming build
I am actually building 2 near identical computers. One will be entirely new, and the other will otherwise be the same except it reuse a few parts from my current PC which I will note.
Gaming
~$1,000
KC, MO
CPU - already purchased (i5 2500k)
Motherboard
RAM
Video Card
PSU
Case
Hard Drive
Optical Drive
For computer 1 (gift) - nothing
For computer 2 (mine) - PSU (CORSAIR CMPSU-620HX 620W MODULAR PWR SUP), Hard drives, optical drive
6) Will you be overclocking?
I never have, but since I snagged 2 i5 2500k CPUs cheaply, I am interested in giving it a shot.
1920x1080 - both
24" - computer 1
27" - computer 2
Within a week.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
Here is where I need some advice. I typically spend around $120 on a motherboard since I don't need a ton of features, but since I might overclock I'm looking at the ASUS P8Z68-V. I typically only have 2 - 3 hard drives, 1 optical drive, and 1 video card (no SLI) and not much else.
Will most likely purchase 2 OEM Win7 64bit Home Premium
I'm currently looking at the following components:
Initial List
Intel i5 2500k (purchased) - $179
ASUS P8Z68-V - $169
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131729
G.SKILL Sniper Low Voltage Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) - $49
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231461
Antec High Current Gamer Series HCG-620 620W - $64
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371048
EVGA SuperClocked 01G-P3-1563-AR GeForce GTX 560 Ti (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 - $249
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130610
Seagate Barracuda ST1000DM003 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive - $149
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840
LIAN LI PC-9F Black Aluminum ATX Mid Tower Computer Case - $119
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112304
Some cheap Lite-On/Samsung/Sony DVD burner - ~$20
Total: ~$998 before shipping
Current List
MSI P67A-G43 (B3) - $114
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130583
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) - $30
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
Total: ~$924 before shipping
As mentioned above I could really use some advice on the motherboard, and anywhere I can save money will look especially good since I'll be buying 2 of most of these components (comp 2 is reusing PSU, optical drive, hard drive).
Those are all solid choices. If you want to save $50 or so on a motherboard, you can look at a P67 instead of Z68.
Maybe:
$134.99 - $104.99 after MIR GIGABYTE GA-P67X-UD3-B3
or:
$114.99 - $94.99 after MIR MSI P67A-G43 (B3)
Or if you want to stick with Z68:
$149.99 - $129.99 after MIR GIGABYTE GA-Z68XP-UD3
or:
$129.99 - $109.99 after MIR MSI Z68A-G45 (B3)
Also, you can save $7 per by going with the regular 1.5V Sniper kit instead of the 1.25V ones.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231416
Thanks for the suggestions. I'll swap out the memory with what you have linked. It looks like I'll have to do some reading on P67 vs Z68, but at the very least the GIGABYTE GA-Z68XP-UD3 should work nicely for me.
Thanks Tsuyoi, that's exactly what I'm looking for. Reading articles and spec sheets of all these motherboards was making my head spin.
Looks like I'll go with the MSI P67A-G43 (B3) that Forceman linked above. About what I normally spend and has all the features I need.
Also, $30 for 8GB of RAM is tough to beat. I'll go with that if it's back in stock when I place the order.
Oh wow, those sold like hotcakes. Was still in stock when I posted the link.
