Hey,
I need some help here. Ive been overclocking for about 8 years now and have had some pretty kick ass systems, so Id like to think I at least have a clue. My latest rig is giving me fits and Id like to get some opinions on where to throw the money next.
The config is this:
A64 3700 San Diego
2x512MB PDP Patriot PC3200LL
ASUS A8N-SLI Premium
XFX 7800GT
Antec TruePower II 480
Everything was new except for the CPU. I bought it used. The prior owner claimed to have had it stable at 2.8GHz on a DFI board with ~1.65v (IIRC), with the HTT around 300. I believe that he did, only because when I first bought it a few months back I was able to get it up near 2.7GHz with some stability at ~1.58v. That was on quiet air using a Zalman CNPS-7000Cu at 7v. The problem was that getting there was a hell of a challenge, as even hitting 2.4GHz was tricky and I had to tweak the shit out of the memory timings to get it to boot anywhere above stock.
Keep in mind Im not looking for max overclock here. If I can get it up near 2.5-2.6GHz, Ill be satisfied. That said, I just finished a water cooling setup that keeps it cooler and even a bit quieter. Now I cant get the friggin thing to POST above stock no matter what I do. I can keep the RAM timings tight at 2-3-2-5-1T when stock, and the CPU idles at 29C and peaks under load at 36C (22C ambient), so I know the cooling loop is getting the job done. (Storm, D5, BIP X-flow, etc.)
What the frick should I do? Is it the memory controller(s) in the CPU? The RAM? The board? Im just at a loss at what to try next, and I dont have any other parts of this caliber to test with. Ive also tried pulling a stick of RAM and had a little more success, but nothing that one would consider fully stable.
EDIT: Wanted to add that my HTT seems capped around 240-245...
Ive got my eyes on a new Opteron 165 should I go for it?
Thanks in advance!
Tom
The config is this:
A64 3700 San Diego
XFX 7800GT
Thanks in advance!
Tom
