OK, I've been reading a lot about NAS devices. I started my research a couple of weeks ago and it seems like every time I turn around I discover a better way. The posts here have been some of the best resources I've found. (Thanks!) But most are dealing in much larger solutions than I can afford at this time.
Unfortunately, I have to create my NAS on a very tight budget. I've got about 2TB of files that I want to be available on my network - mostly for streaming media, and some for user file storage (docs, pics, etc.). Of course, that will grow a lot if I have some room to expand.
I currently have a mini-ITX Via EPIA M10000 system running FreeNAS v0.7. It has 1GB of RAM, a 160GB system drive (IDE) and a 500GB storage drive (USB 2). This motherboard does not have three key features: SATA, GigE, or PCIe. But for now it serves media just fine. The problem is adding space to it. It only has one PCI slot. So I can either add a GigE network card OR a SATA controller, but not both.
I currently get about 11MB/s transfer rates from it, which is about the max for the 100BaseTX network interface. My network is GigE (everything else in the house), so I think I could get better transfer rates by upgrading the network interface on the FreeNAS box.
But I also need to add more storage. So where will my bottleneck be if I add a PCI GigE card and USB 2 drives? What kind of speed can I expect?
If I were to build a new PC with GigE, SATA and more RAM, what kind of speed improvements should I expect for my money?
Should I just buy an appliance (like a Qnap TS-210)? It would be cheaper than a new PC, but would not allow for later expansion. Is it worth it?
