Recently given an old HP and old Compaq comuters I decided to rob the systems of parts and ressurect a Gigabyte GA-7ZX with a Duron 750 using the other computers RAM, Hard-drive, cables, Cd-drives and power supplies (the last of which turned into a no-go and I put a junk 500watt in there... seems to work)
Well... I've run into a /slight/ problem when booting. I say slight because it doesn't appear to affect the computers actual operation and just only annoys me when the computer gets turned on.
The second drive, which reports itself as a Samsung, gets this "Atapi not enabled" error when turning the computer on, and I'm instructed to go modify the bios or resume boot...
Resume boot... and WinME/Win2k load and run with no problems no matter which one I choose.
Do any of the guru's hear have a CLUE what's causing this thing?
and as I'm rebooting to make sure I copied the error down...
I realize that it says
SEC SLAVE ATAPI NOT ENABLED
... which is my CD-rom drive...
and sure enough... my cd-rom is not listed in the computer.
Okay. I'm blind.
And Stupid. I missed where the cables actually led to... and had the bios assigning the wrong devices.
Fixed. :/
Okay. I'm blind.
Fixed. :/
