Deadjasper
- Oct 28, 2001
I have a couple of computers on my network that I don't want connected to the Internet. I accomplish this by putting them in different subnet with no gateway. The other computers have 2 NICs, one assigned IP by DHCP and the other manually assigned the same subnet as the 2 non Internet computers. This works just fine in Windows. I can access both subnets via Windows Explorer and transfer files between the two and also use other resources such as Printers, etc.
But not so in Ubuntu-MATE. I have connectivity, I can ping the two computers and I can remote into them using Remmina. But they do not show up in Caja.
Anybody know how to fix this?
btw: I'm not using a VPN because I have 2 clusters of computers using one physical connection between routers so I have no way to segregate the VPN connections per computer.
Thanks
Thanks
