Need some input
ApocalypZ
My new system :
P4 3.4C 800FSB
512MB CorsairXMS PC3200LL (2-3-2-7)
Abit IC7-G MaxII Advance
Zalman 7000A-Cu HSF
WD Raptor 74GB 10,000RPM SATA
Seagate 200GB 7200.7 SATA
ATI Radeon 9800 Pro
Soundblaster Audigy 2 ZS
Liteon 16x DVD
Liteon 52x/16x CD-RW/DVD
Antec True480 480W PSU
Lian Li PC-6070A
What do you all think of this? How well do you think i will be able to overclock? Is this worth getting instead of the amd64's since they are so pricey? (i get a new pc about every 8 months)
It would be for games / general use / music. I play Doom 3, CS, and CS: Source. Do you think these games will run well on this system?
needs more ram for D3
*edit* also, the a64's aren't that much more pricey (if at all) then what you've got there from Intel...and will provide considerably better gaming performance...
ok what if i mixed ram tho? i cant find this same stick on newegg anymore... what if i got a corsair xms 2-3-3-6 stick and put these two together... i messed up... the one above is actually 2-3-2-6... wil they work fine together?
stick with the same ram.... It will cause trouble if you mix them.
