Need some input on upcoming build
Mnx4
Hey. I'm prolly getting an x2 4200+ and ocing and I'm trying to find an adequate colling solution. My old pc was an 1900+ with water cooling with an older water cooling kit from innovatek (here) .
Now, here's the thing. I'm looking into either an xp-90c , or perhaps getting a danger den TDX . I guess my concern is would I have to upgrade to a different pump size or are there adapters out there? The innovatek came with 1/4 tubing and an eheim 1046 pump so I don't know if that's inadequate or if I could just use different tubing or something. I don't HAVE to water cool, i would just hate to see the kit go to waste. Any suggestions?
Instead of the xp-90c..go for the xp-90 ($25 @ svc right now) and a TT SilentCat or Panaflow m1a....much cheaper than the copper version and the 2-3c it gives.
As for wc, the tdx block in kinda restrictive, but you do get different nozzles, so try the highest flow one.....the eheim 1046 is a bit on the weak side. Try it, and if temps are what you expect, then get a bigger pump.
