Ok so I can not seem to figure out what the problem is on this new rig and hoping you guys can help me out with ideas. I have installed Win7 Ult on the hard drive without any GPU's attached, updated bios, installed all the windows updates, and here comes my issue. I plug in my GPU's and I can not get it to boot with more than 2 GPU's in. Specifically the first and second PCIe16 slots. If I plug in the PCIex1 slot I get past the Bios screen put it stops with a blinking cursor immediately afterwards. if all 4 are plugged in I can't get any display at all. Tested each GPU and each slot and they are all working properly by themselves it is just when I try to run them all together. I am running out of ideas
Specs:
Z87 ASRock Extreme4
LEPA 1200W PSU,
4xSapphire 280x Dual-X
4gb single ram
G3220
Any ideas would be greatly appreciated. This one is driving me up the wall. The only thing I could think of is that the PSU isn't putting out enough power for 4 but there should be no way that a 1200W LEPA 80+ Gold can't power even 3 GPU's. . .? I am wondering if this a motherboard issue since I didn't have any issues at all last time. . . Frustrations galore on this one.
Specs:
Z87 ASRock Extreme4
LEPA 1200W PSU,
4gb single ram
G3220
