Need some help.
demetrics
I have a AMD 3500+ 939 CPU and a K8V DELUXE Motherboard. Any I have something called an AI overclock for my CPU and it is set to AUTO. Some of the option are "manual, standard, overclock 3%, overclock 4% and etc..." Basically I want to know is the AI overclock on Auto causeing my CPU to run above 3500+ because can't that cause some overheating problems, I only the standard heatsink and fan that came with it. I bought the CPU on Retail. What is the difference between manual and standard? If I set it to standard will it become more stable and just stay at the default settings of 3500+.
I don't know how this thing works.. but I'm sure it wouldn't allow unstable settings.. as for the temps - install motherboard monitor so you can monitor them..
dont mean to change topic, but taht brings me to my problem... my cpu (see sig.) has a little problem with temperature as well, i have a zalman CU heatsink on it, its constantly running on 2600rpm m(with its own controll it only goes up to 2400) my mainboard has two fans on it, plus two 80mm fans.. as soon as i close my case, the cpu without being under load, goes up to 62 degrees... waht the hell is wrong here?
