Need some help
transam02
I have a Sony DRU-170C and it is starting to read and then not read disk. I was wondering if there was a place I could get the driver but I cant find it on there site it just says to download the service pack 1 for xp. I have to take out and put the disk in several times. just to get it to work and then it will work for a lil while then stop. Heck sometimes I can get BF2 to work and it will work for several days and then not.
Drivers won't help you. You need to check your data cable, failing which you can assume that
your drive is probably dying.
