So, I'm trying to do a IDE with SATA harddrive right now. Of course it will work as I tried it before but the problem is.. the IDE is now loaded with Fedora OS which is for school and I have a drive enclosure for it. I'm trying to run it with my PC so I can do some homework and etc but it doesn't let me load it. Any ideas why?? I unplugged my SATA HD to see if it will run but no luck.. I enabled IDE usage in BIOS and have set harddrive to boot off first. But still no luck. It loads to some MAC thing and continues going...
edit: The drive enclosure is also another IDE cable plug in thing. There's no USB cable to connect it.
