So, I have an X-Fi XtremeGamer, and it works great, but I'm in a bit of a bind when it comes to front panel audio. The X-Fi has the standardized connection, like many cases have, where it's a 2x5 pin keyed connector (dubbed Intel HD Front Panel Audio standard header in the manual). I have a Silverstone TJ06, and for some freakish reason they didn't put one of these connectors on the front panel audio connector, though it has them for USB and Firewire. Here is a layout of the header pins on the card:
The pins go something like this:
Pin
Signal Name
Description
1
PORT 1L
Analog Port 1 - left channel (Microphone)
2
GND
Ground
3
PORT 1R
Analog Port 1 - right channel (Microphone)
4
PRESENCE#
Active low signal that signals BIOS that an Intel HD Audio dongle is connected to the analog header. PRESENCE# = 0 when an Intel HD Audio dongle is connected
5
PORT 2R
Analog Port 2 - right channel (Headphone)
6
SENSE1_RETURN
Jack detection return for front panel (JACK1)
7
SENSE_SEND
Jack detection sense line from the Intel HD Audio CODEC jack detection resistor network
8
KEY
Connector Key (no electrical connection)
9
PORT 2L
Analog Port 2 - left channel (Headphone)
10
SENSE2_RETURN
Jack detection return for front panel (JACK2)
The front panel connections for my case are nothing like this. It's not a standardized connector, rather individual connections. They read like:
Pin
Signal Name
1
L OUT
2
R OUT
3
L RET
4
R RET
5
MIC IN
6
MIC POWER
7
GROUND
So this is my dilemma. I don't know how to connect half of the connectors. Has anyone else run into this? I'm going to e-mail Creative and see if they have any pointers on the matter
Pin
Signal Name
Description
1
PORT 1L
2
GND
Ground
3
PORT 1R
4
PRESENCE#
5
PORT 2R
6
SENSE1_RETURN
7
SENSE_SEND
8
KEY
9
PORT 2L
10
SENSE2_RETURN
Pin
Signal Name
1
L OUT
2
R OUT
3
L RET
4
R RET
5
MIC IN
6
MIC POWER
7
GROUND
