Canadian in Berlin
- Sep 8, 2007
I've tried posting this on the ubuntu forums but nobody seems able or willing to help, so I thought I'd give it a shot here, maybe somebody here has an idea?
My wife installed updates now almost a month ago (as she always does when they appear). Since then numerous problems have started happening. I'll start in order from booting.
PROBLEM ONE:
Login to Ubuntu, desktop appears, popup in the bottom right corner saying:
"The configuration defaults for GNOME Power Manager have not been installed correctly. Please contact your system administrator"
I did some googling and somebody said I should simply re-install the package. So I went to open up synaptic... I got the 'dpkg --configure -a' problem. Ok, ran the command and then it worked. Fine. Re-installed the package, and went to reboot!
PROBLEM TWO:
CLick on the little green shutdown menu man. Instead of getting the window with all the possible options, it just logs me out, then I can reboot. I'm hoping this is related to the first problem?
Log back into Ubuntu, and it still gives me the error message. I try and ignore it for now and will deal with it later. I wanted to install GNOMAD for my Creative MP3 player, I go to open up the add/remove programs program from the Applications menu, and it starts with the "starting Add/Remove..." in the taskbar, then disappears. In the system logs I don't see any sort of error (or any reaction at all). Well, wondering if perhaps theres a new kernel and its buggered, I go to start up the startup manager to change to a working kernel... I click on it, enter the password and it won't open. Again nothing in the system logs. I also checked the running processes, no sign of any of them there.
A list of System Programs that won't open:
Preferences:
- Main Menu
Administration:
- Hardware Drivers
- Hardware Testing
- Software Sources
- Startup Manager
- Update Manager
Other noticed symptoms:
- Programs that used to minimize to the tray when closed no longer do so, they just close. None of these programs can now be sent ot the tray.
- After the updates, the minimize/maximize/close buttons (dash, box, X) in all the windows were turned off, I fixed this in the "Windows" tool afterwards, but they WERE changed.
I posted this elsewhere a few weeks ago and got only this response that didn't help me:
My output:
Another person asked for my hosts file, but never responded afterwards:
PROBLEM ONE:
PROBLEM TWO:
Preferences:
- Main Menu
Administration:
- Hardware Drivers
- Hardware Testing
- Software Sources
- Startup Manager
- Update Manager
Code:
Quote:
You may want to check if the upgrade was succesful. If you can open a terminal and run the following commands. Are these succesful and are using the correct release?
# sudo apt-get update
# sudo apt-get dist-upgrade
My output:
Code:
Quote:
Error with:
sudo apt-get update
Ign http://packages.medibuntu.org hardy Release.gpg
Ign http://packages.medibuntu.org hardy/free Translation-en_US
Ign http://packages.medibuntu.org hardy/non-free Translation-en_US
Ign http://packages.medibuntu.org hardy/free Packages
Ign http://packages.medibuntu.org hardy/non-free Packages
Err http://packages.medibuntu.org hardy/free Packages
510 Not Extended [IP: 87.98.242.10 80]
Err http://packages.medibuntu.org hardy/non-free Packages
Fetched 801kB in 25s (31.8kB/s)
W: Failed to fetch http://packages.medibuntu.org/dists/...86/Packages.gz 510 Not Extended [IP: 87.98.242.10 80]
E: Some index files failed to download, they have been ignored, or old ones used instead.
sudo apt-get dist-upgrade updated Firefox and flash.
127.0.0.1 localhost
127.0.1.1 maren-desktop
# The following lines are desirable for IPv6 capable hosts
::1 ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
ff02::3 ip6-allhosts
