Need some help with my new system
Numan
I seem to have an endless serious of problems with my favorite hobby and maybe I should replace it with my second favorite, which is drinking :)
Recently I posted a thread on here about how I upgraded my rig to include the Asus P5N-D (Sorry, I am at work and cannot access some sites. The mobo is the Asus Nforce 750i flavor), Q6600 Intel Quad Core and my upgraded Cooler Master 650w PSU. This was added to 4 gigs of Kingston 667 DDR ram in 4 sticks, an SB Xfi and two BFG 8800GTs. I cannot even find the post here anymore but the initial problem was this crazy “stutter” that I got every few seconds which was dynamic; the screen would pause and the sound with it. I tried many, many, many things and then as a last try for the heck of it I hooked up my old 550w PSU to this rig with only one 8800GT plugged in and the stuttering got worse. My little brain went off as I tried the Cooler Master in this same config and the stuttering was much less. I exchanged the Cooler Master for an OCZ 700w and my stuttering went away in every game! No micro stutter in SLI either with cranked details in UT3, HL2/TF2 and WoW.
So why am I posting this now? Well, this was before my OC attempt. I nudged the volts up a little on everything but the video and the ram to get that Q6600 running at 3Ghz. I also installed 3dMark06 just for show. Well the stuttering is back but just in 3dMark and at one point a BSOD. People are telling me not to worry about 3dMark as it’s just for epeen but my concern is that shouldn’t everything on the system be strong enough to not have issues? Maybe I need a PSU with super strong 12v rails? I didn’t think I would really need something that strong as I kept reading that two 8800GTs use less power then my old 8800GTS 320. Also, while ‘testing’ the stability in Warcraft last night I had parity error and the message on the blue screen didn’t say much more then that. Never seen a blue screen in that format before either. Would my overclock mess up the RAM even though I am not touching the RAM or because of the multiple sticks? I was hoping to try to get to 3.4Ghz although I would take a stable 3.0 if that’s all I can get. As far as the stuttering, all I can think of doing is installing a few more games when I get home (Crysis definitely being one, just to max it out to attempt to recreate the stutter) and go from there. The guy at the store was dead set that my problem wasn’t PSU related and if I go back there he might complain. I am half tempted to tell them I want 4 gigs of 800 DDR2 and a system stable enough to run these games and 3dMark just to make me feel better in the back of my mind.
I apologize for being all over the place with this post but I want to fix my dream desktop :(
The joys of of overclocking!:( BTW, drinking is my favorite hobby!
Did you revalidate your system when you made the changes by doing a Prime 95 burn in test? This is why I'm not a big overclocking fan, instability bites you when your not expecting it.
You need to do a Prime 95 stress test to see how long it runs before something craps out. My guess is that it won't run long before you see problems. At that point if you see ANYTHING, you need back off your overclock. Probably need to start over from scratch unless you've been revalidating your overclock as you've gone along.
I don't think there's any quick and dirty way around retesting unfortunately.
No but I did post this in another forum on here and had my origanal post of getting the thing to work at all in another. I'm all over the place, my bad.
I'll try Prime95. Just wish I could rule out what's disturbing the OC as I would like to at least get 3.0Ghz out of this if not higher.
Thanks
