erehwon6811
- Aug 5, 2004
I got this old barcode scanner I'm trying to get up and running so I can use it with a media cataloging system called Opendb. The scanner is a Intermec 9510 that comes with a wand. I also have an Intermec 1620 laser scanner that plugs into the into the other thing. Those links are all I've been able to find on them since they're so old.
I'm trying to figure out if there is a driver or some kind of configuration I need to do to get it to work in XP. I have it pluged in and it seems to work. The laser scanner will read, but nothing comes up in word, excel, or access. It connects into the computer through a parallel cable.
