Need some help regarding a new system
dmwc
Hey all,
I just discovered this forum and thought I'd get some expert opinions.
I built my current PC 5 years ago and I have decided it's finally time to upgrade. The problem is, it's been 5 years since I've built a PC or even really looked at PC parts online. Suddenly, I'm a bit overwhelmed by how things have changed and all the choices there are out there. So I'd like to run a couple of questions by you folks here and see what you think. Keep in mind I'm on a bit of a budget and I can't really go for the really high-end stuff, unfortunately.
Here's what I'm currently thinking of picking up:
- AMD Athlon 64 X2 3800+ Dual Core processor
- Nvidia GeForce 7300GT 256 MB graphics card
- 1 GB RAM (not sure what brand yet)
- Apevia X-Gear mid-tower case with 420w power supply (not sure about this yet)
I really have no idea which motherboard to get. Any suggestions? Also is a 420w power supply going to be enough once I get everything in there? I'm going to be transferring my video capture card, hard drive, and DVD burner from my current PC to the new one (my hard drive is less than 3 years old, my DVD burner less than 2) as well as a zip drive and floppy.
Also, is it worth the extra money to move up to the Athlon 4000+ or 4200+ or am I really going to see much increase in speed?
Last but not least, what is the best place online to get parts?
Thanks,
Dmwc
everybody here is going to tell you to go with the core 2 duo :cool:
haha, yeah start here http://www.newegg.com/Product/Product.asp?Item=N82E16819115005
Can get a mainboard for around $100 also.
What's your overall budget though? That would help. Also, with the selection of the 7300 card, I'm assuming you're not going to be gaming a whole lot?
For shopping for parts, you can first check http://www.resellerratings.com
Some common places are
http://www.mwave.com
http://www.zipzoomfly.com
I'd like to stay under $700. And you're right, I'm probably not going to be doing much gaming. I'll be using the machine for more video editing and DVD authoring than anything else. My current 5 year old machine can handle editing and such well enough, but rendering stuff in After Effects and rendering MPEG-2 for DVD is pretty darn slow and I know this thing won't run Windows Vista should I decide to upgrade at some point in the future.
What's the best speed for the money in Core 2 Duo? I was leaning toward AMD only because that's whats in my current machine, but I can go either direction.
Core2Duo will give you the best performance for your money. Here's some reading material for you.
http://anandtech.com/cpuchipsets/showdoc.aspx?i=2903
http://anandtech.com/cpuchipsets/showdoc.aspx?i=2802
http://anandtech.com/cpuchipsets/showdoc.aspx?i=2795
http://dailytech.com/article.aspx?newsid=5414
This should get you to 3.0Ghz easily, without sacrificing any stability:
$163 - Intel Core 2 Duo E4300 Allendale 1.8GHz 2MB L2 Cache
$105 - Biostar TForce965PT LGA 775 Intel P965 Express (review)
$68 - Kingston 1GB DDR2-667 KVR667D2/1GR
$38 - Leadtek PX7300GS TDH 128MB Supporting to 256MB(128MB on Board) ($53 - $15MIR)
$80 - Seagate Barracuda 7200.10 ST3250620AS 250GB 7200RPM SATA300 16MB Cache
$43 - Topower/Epower EP-500XP Xtrem 500W OEM
$31 - Lite-On 16X DVD±R DVD Burner Black SATA Model SH-16A7S-05
$10 - Ultra Wizard Blue Mid ATX Tower Case ($40 - $40MIR + ~$10 Shipping)
$671 + tax and shipping - $55 MIRs = ~$700
The OC numbers for that setup would be:
E4300: 9 * 200 = 1.8Ghz, 2 * 200 = DDR2-400 (stock)
E4300: 9 * 333 = 3.0Ghz, 2 * 333 = DDR2-667 (overclocked)
if you want to save more money, you could go for this PSU instead, since you don't have a demanding videocard:
$0 - Ultra V Series 500W Power Supply ($40 - $40MIR + ~$10 Shipping)
If you want a nicer case, go for this:
$40 - Cooler Master Centurion 534 RC-534-KKN2-GP Black
If you need a bigger HDD:
$110 - Samsung SpinPoint T HD400LJ 400GB 7200RPM SATA300 8MB Cache
Oh, and this will run Windows Vista just fine. Although, I wouldn't recommend switching to it until at least SP1. Until DX10 games come out, there really is no advantage to it other than looks. If you can wait until April 22nd, you should be able to get the E4300 for $113. If you can't wait, then go for it now.
