D
Deleted member 85430
Guest
here's the deal...
480w Thermaltake PP
P4 3.2C
512Mb pc3200 corsair
gigabyte cooler
sata barracuda 80G..
everything is hooked up like it should be...cpu is seated and heatsink is on good with a thin layer of arctic silver.
memory is seated well.
front io panel connectors are correct...
when i power it on, the fans try to spin up and gigabyte cooler's led's flicker for a split second. then nothing...the power supply does make a strange clicking noise. i have to unplug the power from the psu for a few seconds to even get it to that much when i try it again...
i made sure the board wasn't shorting on anything and its not..
thanks in advance,
sam.
480w Thermaltake PP
P4 3.2C
gigabyte cooler
thanks in advance,
sam.
