I
iGROCK
Guest
For the last year or so I have been using the Corsair H100 WK kit for my 3570k that is OC'd to 4.5GHz. I have recently ordered an 290x which you might be aware has heating "issues", if you will.
I have already made up my mind in putting an EK water block on the video card http://www.frozencpu.com/products/2...etal_Nickel_EK-FC_R9-290X_-_AcetalNickel.html
But, now I need to get the rest of the components such as a water block for the CPU and the rest of the components. Which one is best for the money?
I would like to go with 1/2 x 3/4 tubing. I havent decided which pump to get but I hear Swiftech MCP655 is good? But it says its been discontinued.
My Corsair Obsidian Series 650D Case is able to accommodate a 120mm Radiator mouted up top, will that be enough to cool both the CPU and 290X?
I dont really want to spend a ton, but I dont want cheap parts either. I would appreciate any input on this. Thanks everyone.
