valleyman86
- Apr 29, 2011
Here is the Spreadsheet of what I want to purchase
Disclaimer: I am new to this WC scene and have always wanted to do it. I have done research a few times building a dream setup or basically what I would buy if I did buy it. Well I just ordered a new PC with the new Thermaltake Level 10 GT case. I realize this case isn't the uber water cooling case everyone loves (HAF) but I do like it a lot. Now I have made another setup for my water cooling dreams and oddly enough hardly anything has changed over the years... Tl;DR - I am a newb please help.
About My Setup: Ok so I pieced it all together with cost into a spreadsheet for easy understanding and comparisons. What do you guys think about this? I want to get the best performance I can for the cost. If I have to spend $50 more for a 2-3 degree improvement then no thanks. Im not hardcore but I do plan to overclock my 2500k as much as I can for full time use. I will not be going with a GPU block this round as it adds significant cost and I dont plan on overclocking my video card. I will add this to the loop later so I need to make sure I have enough flow. I will probably need to add an additional radiator (see below for question).
Flow Plan: I would like to put my pump in the bays because this area is never used. I have 1 burner and thats it. I want the radiator to be on the top of the case with fans blowing out in a push config. The fluid will then flow the the CPU and then to the reservoir. For the reservoir I want to either A) mount it on the rear fan (not sure if this is possible because the fan is 140mm. Hmmmm B) Mount it on the radiator so that it is visible in the smallish side window on my case. I think this would look awesome. Then the flow goes back to the pump.
Questions:
1) I am not sure how to mount or where to mount my pump. I want it in the bays but are there any cheap ways to mount it here while keeping vibrations down and not resorting to a new top or res/top?
2) Kind of pertaining to the 1st question I was thinking I could get an xspc d5 res/top and mount everything very easily in the bays. This is ok but I dont know if I trust the acrylic as there has been bad issues in the past as I have read. It also makes my setup look less cool without my plan to mount a round res viewable in the side window.
3) Can I mount the DD Tube Res sideways? Is this a good idea I guess. I am a bit scared that if it ever leaked it would leak on my video cards...
4) I am not sure what to get for liquid/fans. I plan on buying some cheapos for use as shrouds but other than that I have no idea what fans to get for my setup. I read some review that said the radiator is better for low cfm quiet fans. For liquid it sounds like its best to use distilled water and additives? What additives do I need and should I worry about conductivity of it?
5) Is there a way to bring these prices down? I wanted to keep the cost about <$300.
6) I am pretty sure I had another question but I cant think of it at the moment.
Questions:
