Need some help please
menace2society
I'm think about a system upgrade. I currently have a system that containes the following. Asus Crosshair MB. Athlon 64 X2 4600+ Windsor 2.4GHz, OCZ Gold 2GB DDR2 800, EVGA 7950 GX2, BenQ FP241W Black 24". The problem I have is that I run a water cooling setup with a Swiftech Apogee GT waterblock I have the intel adapter plate but I have never built an intel system before. How much different is it? And woul it be better to change the motherboard and cpu or get a new 8800 gtx. buget is around $600. I'm doing this because the Bioshock Demo brought my system to it nees. I try to run all my games at 1900x1280 with as many of the bells and whistles turned on a possible Thanx :confused:
You will need to replace the adapter on your apogee but it shouldn't be too much of a problem. It's different but Swiftech should have the necessary parts for it. Your 7950 GX2 should be ok as it meets the Recommended system requirements of bioshock. However 1900x1280 is no joke and that will give even some of the latest video cards something to sweat about.
You may benefit a great deal with upgrading the mobo/cpu to a core duo 6850 and oc it a bit. with 600 you should be able to do this easily, sell off your graphics card and have enough to get an 8800gts.
Just OC ya CPU to 2.8Ghz or so , and if necesary drop down to a lower resolution, your vidcard only uses it's full potential if the game code is well writen for SLI, mine was slower than my other 7900GTX in some games... if I would upgrade I would only spend money on a faster GFX card as you stil have some headroom with the CPU...and demos can be painstakingly slow as the gamecode is not up to scratch (yet)
( not 8800GTS 320 as it won't cope , I even have my doubts for the 640Mb version at your wanted resolution)
Just await full release and OC some to get some extra CPU powaaar...save ya cash
On a note I read some tests of DX10 games and even with a 8800GTX , Core2 at 3.6Ghz it barely reached playable levels at max detail and high res ( 1600 x1200)
Thanx for the info people:cool: I,ve read that dx10 puts the hurt everything thats out now. Would it be better to upgrade Mb & cpu and just wait for the next gen graphic cards. Or is there life still left in the AM x2 platform. FYI: overclocked both MB & GPU and 1900 x1200 still a struggle
Did you try the new beta drivers from Nvidia with improved performance for Bioshock, I think it's time to drop down to 1600 x 1200 or even 1280 x 1024... just await the final release of the game, mostly the full versions work better then demos ....
I hope for you the Asus board supports the upcoming AM+ CPU's and the game will be nicely supported by your Gfx card..
