rabiddawgs
- Aug 16, 2004
my system specs are as follows. a7n8x-e, xp2500 (small oc to 1984mhz), 2x256 corsair xms pc3200LL standard cooling.
i currently have a ti4200 128 mb ram vid card. about 5 months ago the fan decided to stop.
it is a visiontek card and they epoxied the hsf on it. i looked all over the web and found the trick of putting it in the freezer. did this and it sounded like glass shattering. i installed a new hsf on it and all was well until about a month or 2 ago. starts locking up in games.
2d apps work fine.
i was wanting to update the vid card and wanted some opinions on which way to go. i have roughly 400 to spend.
i play mostly fps type games and will be getting d3 and hl2.
1. buy the 6800gt = $400
2. buy the 5900xt and another 512 ram ( or sell the 2x256 and get 2x512) = $400
3. buy the 6800 base card pocket the $100 left and i might be able to get 512 at a later date. = $300 and then $200 later for the ram
are there any soft mods for the 6800 base or 5900xt out there.
OR
i have a p4 2.8 800fsb, 2x256 buffalo ram and intel d865glc mb that i could sell and get the gt and 512 ram. i am not really useing it and i think i could get atleast 300 for all this.
i need this to last me for atleast a year and a half at the min.
all the help would be apprectiated
thanks in advance
dawg
2d apps work fine.
OR
thanks in advance
dawg
