solaris389
- Dec 2, 2010
Over the past couple of days I have noticed some bad behavior out of my computer. It first started with my GPU fan blowing full speed all of a sudden when watching a video in Firefox. The fan started at full blast as well when I shut the computer down and restarted it. Catalyst Control showed everything was normal at first, but manual control of the fan would not work.after a few restarts, Catalyst Control did not show the GPU working at all adn showed the GPU temp at -128C. The behavior continued until I removed the card, restarted the computer with integrated graphics, and reinstalled the GPU. It worked like normal for a few days but the fan started blowing full blast again yesterday. I could not get the fan speed back down this time and have removed the GPU and am using integrated graphics for the time being. I looked up information about that behavior it suggested it could be the PSU. I installed Asus AI Suite ll to record the voltage and temps yesterday. Since then, I have had multiple low voltage alerts and negative CPU temp alerts. I can get a different GPU to test out, but with what AI Suite is showing, I am looking more at the PSU or Motherboard. Any help narrowing it down between the two would be appreciated.
System Specs:
Windows 8.1 Pro 64-bit (fully patched)
Asus MAXIMUS V GENE Z77 (latest BIOS)
Intel Core i5-3570K
Corsair Vengeance 16GB DDR3 1866 MHz
Samsung 840 PRO (latest firmware)
WD Black 1TB
HIS Radeon 6970 reference cooler (Multiple drivers affected. Latest was 15.4 beta aka GTAV driver.)
System Specs:
Intel Core i5-3570K
WD Black 1TB
