Need some help here,please.Performance issues
yetyhunter
I'm not sure if it's the right section but here it is.
I don't actually know what happened but I lost about 20 FPS in crysis wars.It was running extremely smooth at a constant 60 FPS(v sync) NEVER EVER WENT under 55. But now constantly stays at about 40 -45(at 60 when on the edge of the map,I don't know why),drops very low especially when looking at the center of the map .It lags most when there are allot of players on the server. I always played on the same server with the same amount of players and ran great at 60.
I reinstalled vista(clean install),I even installed windows
7 which i'm running now,installed latest bios,tried many different drivers,I OC my CPU further(it was at 3.6 before)with the same result).
If it's not the OS then what is it?
Pings are very good usually at 50 or lower.
Any suggestions,please? :(
wow 60fps man what kind of settings are you using.. lol
has there been any updates for the game recently? updated video drivers? accidentally change your global settings in your drivers? add a second monitor? enable or disable directx10 support?
but honestly if the server starts lagging when theres a lot of people on usually the problem is server side.. either theres a memory leak in dedicated server application or it just needs to be restarted.. i would try joining a few different servers see if your frame rate improves..
Post full system specs, or it never happened. In other words, if you aren't running low settings at 1024x768 or tri-SLI GTX 285s, it was almost certainly all in your head to begin with.
E8400 3800 mhz,4GB ram, GTS 512 SLI @ 740 mhz.I'm running the game all on high 1280x1024,x2aa.
The game WAS running at constant 60 FPS.I'm not liyng.Using patch n°4,I updated recently from n°3
