wol-va-rine
- Jul 20, 2008
I flashed my XFX5850 to the ASUS bios yesterday and thought I had bricked the card, but the card is recognized so I'm guessing it's salvageable...
here's a rundown of what transpired...
1. I flashed my XFX5850 with ASUS bios, it completed without any errors, but my computer wouldn't output video (all the motherboard lights were on, the 5850 fan was spinning, but no video output)...
2. I put my 4890 in and it booted up fine, I browsed the web a little and then decided to try to "fix" things...
3. I then took the 4890 out, put my 4850 in the 1st PCIE slot (I couldn't find a 2nd set of PCIE cables for my HX620 so I couldn't use my 4890 at the same time as my 5850 as both need 2 PCIE connectors, while the 4850 needed only 1 and I had a 4 pin molex adapter) and the 5850 in the 2nd PCIE slot...
4. both cards were recognized with the -i command (adapter 0: RV770 and adapter 1: Cypress), I then flashed the 5850 bios back to the XFX bios, it completed without error...
5.put 5850 back in by itself and again (same as 1.) it wouldn't display video...
6. put the 4890 back in and now my computer wouldn't boot, video was displayed, but it would freeze on the win 7 "starting windows" splash screen, I even left the room for a while (1 hour) and when I came back, still no progress from the splash screen...
then...
6a. I tried loading "normal start up", that didn't work...
6b. I tried loading "last known good configuration", that didn't work...
6c. I tried a windows repair, that completed and didn't work...
6d. I booted into safe mode, that DID work and I did a system restore (I had a restore point from 2 days ago), that didn't work...
7. put 5850 back in and again, no video output at all...
8. put 4890 back in and still the same splash screen problem, just a note, it didn't technically "freeze" on the splash screen any of the times, I could see the win 7 logo "pulsing" or whatever it is that it does, it just go any further than that point...
9. I put my 4850 back in and it booted up, but the video drivers didn't load, the screen was definitely not 1920x1080, so I rebooted...
10. after the reboot the video drivers were loaded and the screen was back to 1920x1080, and [h]ere I am...
any suggestions...?
then...
any suggestions...?
