Some time ago I picked up 2 WRT55AG Linksys routers as I needed one to network, and the other as an access point... I figured... perhaps wrongly at the time, that I could just stick the second router in bridge mode and it'd work like an access point and draw and give the IP's from the first router...
I got it working by going from the Internet router, to a hub, then using the hub uplink to go to the secondary router. It worked great...
until I switched to a gigabit switch, which has no uplink port.
Is there any way to configure the secondary router to work as an access point/hub through the switch? Or should I just give up and get an access point without a router built in.
