I built this system about 8 months ago, AMD X2 4200+ socket AM2, 2 x 1gig corsair 5400 RAM, Foxconn C51XEM2AA nForce 590 SLi, EVGA GeForce 7900GS PCI-e, Ultra 550 watt PSU, one IDE HDD and one SATA HDD, and a DVD-RW drive, running XP sp2
everything had been working perfectly up until today, i start counter strike source and the screen goes black as if its loading the menu but instead after about 10sec my montor says no signal and turns off, so at this point im like wtf so i hard restart my system because it doesnt respond when i ctrl-alt-del or anything. it posts OK and loads XP up to the login screen, but before i can login the monitor shuts off again, same thing. at this point i leave it off and check the temp of my gfx card and everything by touch and everything is running cool, restart again and now it wont even post and ive got no power to mouse/keyboard. mobo lights come on, HDD's spin up, but no signal to monitor or power to keyboard or mouse. At this point i tried booting with one module of ram at a time figuring one of them might have died but no luck there, then i did the same thing with my hard drives, and even switched my gfx card to the other pci-e slot, no luck there either, i dont have another AM2 processor to test so i cant test that. Im thinking its either that or the mobo but i have no experience with those failing so i dont really know what to look for, what do you guys think? also, if the gfx card died, would the system still post, just no OSD? and shouldnt i still get power to my mouse/keyboard?
