Hi everyone,
I am trying to decide on a power supply for my rig:
E6750 (replacing with a 45 nm Quad in the near future)
ASUS Maximus Formula SE
2 x 3870 in CF
4 gb DDR2 800
1 Seagate 320 GB HD
Silverstone TJ-10 case
Since the case I bought has the power supply location at the bottom of the case, I need a power supply with long enough cables to reach the upper 8 pin power connector next to the cpu on my motherboard. I also prefer it to be modular( but it does not have to be) and also enough power so that it would work if I upgraded to a newer video card down the road, like the HD4000 series or something. I was looking at the following:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817703009
http://www.newegg.com/Product/Product.aspx?Item=N82E16817256022
http://www.newegg.com/Product/Product.aspx?Item=N82E16817256011
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153043
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153038
http://www.newegg.com/Product/Product.aspx?Item=N82E16817104043
Also if anyone has any other suggestions that would be cool as well.
Thanks
2 x 3870 in CF
4 gb DDR2 800
1 Seagate 320 GB HD
Thanks
