iv decided to get water cooling but i really have no clue on where to start
from what i understand these are the parts i need:
pump - (i need a pump that puts up a good amount of pressure since i want some long tubing cuz my guess is that it will be messy in my p180 case if i dont have long tubes to work with, maybe even use 2 pumps? i dono)
tubing - (for the tubing wuts the difference between 1/2" and 3/8" wouldnt bigger tubes be better? or would i want smaller ones since i need them somewhat longer, to maintain better pressure? and also i need all the parts to be compatible with the same tube size im guessing)
radiator - (just need a good rad probably with dual fans that can be mounted on the outside)
clamps - (just need tight reliable clamps)
cpu block - (just need an effective cpu block for good temps)
gpu block - (i dont think i need a block that covers the ram unless its really needed and also it cant be too tall, i need one that takes up no more than 1 extra slot of space (so 2 slots including the videocard), just incase i decide to use sli later)
chipset block (optional) - (even tho from what i hear the chipset block being unecessary, the chipset fan can be pretty noisy spinning at 4k-7k rpms and if i do get one i need a fairly small one thats not too tall since itll interfere with my gfx card
reservior (optional) - if this isnt too expensive i think itd be nice to have one to keep track of how much water i have running through the system)
liquid - i think ill just use distilled water and antifreeze here since mct-5 seems too much for liquid and wuts the antifreeze for? kill algae?
also i think ill use dangerden for all the parts unless theres a better online shop
my budget is about $150-200 can be a little more or a little less if it can or needs to be, and i also need this thing to last since im planning on using it for my future systems
thanks in advance
thanks in advance
