Need some help choosing a mobo
RaithVZ
Hey all,
Most of the other components are pretty easy to figure out, Q6600/E8400, 8800GT etc. But for me, I can't quite seem to figure out what motherboard is the right choice for me. I haven't quite decided whether to go with the Q6600 or E8400, and I've read about the temp/compatibility issues about the E8400 from previous threads, but there still seems to be a long list of choices and it seems daunting.
But I know generally what I'm looking for; 2 HDDs, one Raptor and one storage, one optical drive SH203B, 8800GT, DDR2-800 are the components that I have or plan to have. The decision to go either with Q6600 or E8400 changes daily, but since they're both 775, I don't think that they'll impact my decision, however I don't have another 775 CPU to flash with, so out of the box compatibility is important as well.
I'm not intending to overclock it a lot, but I do intend to get an aftermarket HSF for the CPU. I do like the idea of a heat pipe cooling solution but I'm concerned about inverted orientation of the Lian Li A05B, which is part of the reason why I would like some sort of cooling solution on the board since space is tight and I've read about some heat issues with the case. As a personal sense of aesthetic, I don't want to cut holes in the sides or the top of it, I like the sleek and minimalist design, however that does force me to be mindful of my choices.
In terms of use, I plan to do some some work involving fair sized spreadsheet work for gene array data analysis and some gaming (basically a reformed hardcore gamer entering the real world). And I'd like to keep it around $200.
I know I don't know enough to know exactly the motherboard that I need, but taking from previous threads, I hope I've described my needs and intentions throughly.
Let me know if there's any glaring holes in my thought process and I'll gladly fill them in and thanks in advance!
I think a high end P35 motherboard would be fine.
Asus P5K series
Abit IP35 series
Gigabyte P35-DS3/DS4/DQ6 series
Those are your main choices. All are very good, have some good and bad experiences between various users. I know some boards have had issues with Raptor drives for some reason or another, so that would be something you'd need to look into further.
Personally, I'd get the Q6600, but the extra clockspeed of the E8400 would also be a bonus since you're not into OCing.
I found that the A05 had plenty of room for all the cooling I needed to put into it. I had a Thermalright Ultra-120 Extreme in there, and that's one of the larger coolers you can buy. I would suggest some sort of exhaust fan for the top...maybe a PCI slot cooler in the top slot? Or Lian-Li makes a blower bolt-on fan that fits over the PCI slots for their cases. But heat definitely builds up in the top of the case with nowhere to go. The reverse airflow also means that you have to mount your heatsink (or fans depending on the way you go) backwards if you have a fan that doesn't blow down on the motherboard.
Well in terms of addressing the heat pocket at the top of the case, Lian Li makes the bolt on fan right around the top of the case as you had said. I've heard that PCI slot coolers are generally pretty loud. And to further complicate things, I'm assuming that unless I address this heat pocket issue, any sort of aftermarket GPU cooling solution like an Accelero isn't going to be very effective at all.
I think I'm going to try and hold off on committing to a CPU until the April 20th price drop and see how the field looks from there. I'm not in a big hurry, but once my tax refund and/or rebate check come in the mail, it's going to be awful hard to resist.
What are some of the other criteria I should be looking into in order to judge the "quality" of a motherboard? Something along the lines of solid state capacitors being a good thing is about all I know.
You're gonna like what I have to link, @ least for a P35 mobo :D. Gigabyte EP35-DS3R for $133. It has support for the E8400 wolfdale without a bios update so you're set there in case you don't have an xtra 775 cpu lying around like myself. It also doesn't have the somewhat useless(imo) 2nd pci-express slot which is on DS3P and it's an x4 slot(cuts the performance of that 2nd vidcard in 1/2 or worse). Also has the Realtek ALC889A onboard audio chip unlike the cheaper DS3L's ALC888-something(DS3L also doesn't have wolfdale support like the DS3R does, hehe).
