Need some help, can't seem to find my problem.
aznpxdd
Ok, so my PC has been a bitch lately, and I'm not sure how to pinpoint the problem. First of all, I've been getting the IRQL_not_equal_or_less BSOD randomly, even though I did not install any new hardware. Then, anytime I do anything graphics intensive (such as games), my computer would freeze, but what's even weirder is that even if I play a game that is NOT graphic intensive, such as StarCraft, it would also freeze. I've tried reinstalling drivers for both my graphics card and soundcard, none helped. I know for a fact that my GPU isn't overheating, it sits comfortably 30c at idle and ~55c at load. Ok, so I thought...fuck it and I'll just reformat to see it fixes anything. But the problem is...I get hit with TWO different BSOD when I try to reformat. The first one I get of course...is the IRQL again (it says something my USB port), so I removed all USB devices and try Windows CD again. This time, it gives me the "page_fault_in_nonpaged_area" BSOD. I've already tried running memtest and swapping out my ram...still BSOD and freezing.
The PC runs fine in Windows, I can still listen to music, watch HD movies, run dual screen, etc. fine.
Anyone here know what might be the problem?
reinstalling windows from scratch would rule out hardware anomalies,
how could u get a BSOD while reformat? do u mean by reinstalling windows from within windows with the installation cd?
No, the two BSOD hits me while I am at the partition selection screen (to install Windows on).
so u've tried Memtest and have problems, it could be your RAM or mobo
if u have 2 dimms, try using one at a time,
the best way to check if your hardware is malfunctioning is to test it in another PC
I did Memtest and got no errors, and I also swapped out my dimms with my friends'...and still got BSOD and freezing, so I'm pretty sure its not my ram. But I'll have to wait a bit until I can swap out graphics card to check. But from what I have described, it is most likely a hardware problem?
it is possible that yours is a hardware problem, could be your mobo
