So I am using a new mobo (a8n32-sli deluxe) a new gpu (x1900xtx) and a 4400+ x2 proc and it seems that after formating my hard drive (to clear my version of xp and all my old stuff) and beginning to reinstall windows, I get this error when booting:
The BIOS in this system is not fully ACPI compliant. Please contact your system vendor or visit http://www.hardware-update.com for an updated BIOS. If you are unable to obtain an updated BIOS or the latest BIOS supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable the ACPI and allow you to continue your installation.
Inside a dreadful BSOD. So I don't know what to do now. I don't have another HDD to try it on right now, but I don't think thats the problem. I havn't been able to update the BIOS (unless whatever it came with is the most recent) and without being able to make a bootable floopy or get into windows to update the bios, theres nothing I can do.
I am using a 500w ultra x-connect PSU which only has a 20 pin connector and my mobo is a 24 pin, as well as i'm having to use an adaptor for the pci-e molex connector on my GPU.
I tried clearing the CMOS, still have the problem, and there is an option in the BIOS now to disable the ACPI, but after doiing that i'm still having trouble getting into windows and kindof randomly get that BSOD still.
I dunno what to do, someone please help! Thanks!
