Need some help after a CMOS clear
Cali3350
Was testing what my system could and couldnt do and pushed it just a little too hard. Refused to boot. No problem, i cleared the cmos via jumper and started her back up. Set it up to be just like it was before, however after POST when it gets to "Verifying DMI Pool Data.......Update Success" it just refuses to do anything. It will sit there with a blinking curser (though it doesnt accept any commands) and simply pushing down the power button turns the computer off - it does not need to be held down.
Ive tried booting it back up at complete stock settings however i still get stuck in the same area...i could use some help here. Thanks.
first off, mine does that when i have my ipod plugged into it for some weird reason...
also, it would do that if I had overclocked it too much
I can't really help since you said it does it at stock settings.
Well i got it. I had it booting from a HDD that didnt have an OS install before my HDD with windows. Bad Call. NOW it wont boot windows though. It gets stuck immediately after the windows XP screen with the loading bar comes up. It WILL boot into safe mode though. I have no idea whats wrong now.
Sounds like a driver issue. Any other USB devices plugged in? I suppose you could repair install Windows if you had to. Maybe a faulty PCI lock caused some corruption when you OC'd.
