Need some help/advice on adding a second card
Dmitri2012
I'm not familiar with a multi-card setup so I need some help. I currently have a single card:
PALIT GTX560 TI 2GB GDDR5 PCI-E and I want to add another. It appears that they aren't being made anymore. Can I get something comparable or do I need to dump the Palit and get two matching cards?
Thanks in advance!
~Dave
just because their not listed on newegg or other sites doesnt mean you cant find a second.
try contacting palit and seeing if you can buy one from them.
worst comes to worst you can go on ebay
You can get something comparable, brand doesn't matter as long as it's another GTX 560 TI with 2gb of vram.
