I currently have a Asus Maximus Formula motherboard and run a Intel Core 2 Quad Q6600. I just recently purchased a EVGA GTX-280 and noticed that it runs PCI-E 2.0 spec. I can not find anything about my motherboard running PCI-E 2.0 so I assume it runs 1.1 or whatever the first spec is. Would I benefit from upgrading to a motherboard that can run 2.0 spec? Probably something likehttp://www.newegg.com/Product/Product.aspx?Item=N82E16813131284
Next question is about memory. I run Vista 32bit and know there is a 4gb memory limit. I run 4gb of ram, (2x2gb) and the video card is 1gb. I am assuming windows is only using 3gb of memory, correct? Would 64bit Vista be a viable option from here on out?
Thanks for the help.
