Need some hard drive rails...
dbaldus
I'm looking for some plastic hard drive rails to use since one of my other ones broke and I need to use it to mount a second hard drive inside of my tower. Where can I buy some of these?
It might depend on your case. Have you tried google/froogle? I have some but they are proprietary (methinks) to my cases.
..and I'm just talking about the plastic rails that stick into the side of the hard drive, one on each side, to slide it into a mounting rack (or whatever you call that thing) so you don't have to use screws.
Yeah, those aren't standardized. You could get a 5.25" -> 3.5" box, with nice cooling properties, but it's not quite the same thing.
So is there any way I could buy some regular hard drive rails as a replacement for my old ones? Or how do the companies even plan to have you replace a broken one in the first place?
