Need some general input
Finsta
Here's the specs for a PC to be built in the near future:
ANTEC PLUSVIEW1000AMG 21IN CASE 4X5.25 6X3.5 NO P/S W/ WINDOW SIDE PANEL
BFG GEFORCE 6800 GT OC AGP8X 256MB DDR3 VGA DVI S-VIDEO OUT VIDEO CARD RETAIL BOX
ASUS K8N-E DELUXE ATHLON64 S754 NFORCE 250GB DDR AGP 5PCI SATA RAID 1394 1000LAN SOUND MOTHERBOARD
CORSAIR TWINX1024-3200LL PC3200 2X512MB DDR 2-3-2 SILVER HEAT SPREADER
AMD ATHLON 64 3200+ PROCESSOR S754 RETAIL BOX
CREATIVE LABS SOUND BLASTER AUDIGY 2 PCI 24-BIT OEM
LOGITECH X-230 2.1 SPEAKER SYSTEM BLACK 32RMS 64W FDD2
WD CAVIAR SE 200GB HARD DRIVE 7200RPM ATA100 8MB CACHE OEM *3YR MFR. WARRANTY*
LG GSA-4160B DVD+RW 16X4X16 DVD-RW 8X4X16 CDRW 40X24X40 INT IDE BLACK OEM W/ SW
LITEON BLACK 16X DVD-ROM INT E-IDE OEM W/ SW DVD PLAYER
LOGITECH CORDLESS MX DUO MX700 MOUSE KEYBOARD USB PS/2 RETAIL BOX
ANTEC 80MM BRUSHLESS DC FAN KIT
Would an Antec TruePower be able to run this puppy well(it has 3 4pin fans)? Any general suggestions? Don't bug me about the S754 though.
At least 420 - 460 Watts to be safe on an Antec TruPower.
-J.
I'm running a similar system and it's been great so far. The only problem I've encountered involved that motherboard having some issues with the Plextor SATA dvd burner I'm using (after hooking it up, my machine wouldn't even make it far enough in the boot process to let me into the bios....) Solution was to back up to an earlier bios and everything has been fine, though the earlier version did lose a feature or two that were exposed in later releases.
I'm running an Antec Tru480, and it has no problems powering the system.
Might also want to consider an NV5 for the video card if you are interested in improved case/card temps and/or noise levels. The BFG cooler isn't all that noisy, but the NV5 is pretty much dead silent and dropped the temps of both my video card and case.
