Need some feedback about new computer build
lesik
I'm building a computer for a friend of mine, but he doesn't want to spend more than $200. The computer will be used for basic stuff, so no gaming. I got really close, but I have a question regarding my motherboard/CPU. I was searching around on Newegg, and I found this: - BIOSTAR KM266 Pro Chipset Motherboard With AMD Sempron 2200+ CPU. Is it worth buying? I know there's a thread about the PC Chips mobo w/sempron 2400+, but I don't like PC Chips' products. Here's the rest of the specs:
Mobo/CPU:
http://www.newegg.com/app/viewProductDesc.asp?description=56-500-001&depa=0
Hard Drive:
Seagate 20GB UATA100 5400 RPM 2MB
http://www.memorylabs.net/oemwhlase20u.html
CD-RW Drive:
LG 52x32x52 Internal CDRW Drive, Model GCE-8525BB
http://www.bestbargainpc.com/lg52cddrgcbe.html
Ram:
256MB 32x64 DDR Memory Module PC2100 266mhz Standard OEM
http://www.enetshoponline.com/25pc26stoemf.html
Case:
(Beige)Powmax 826PL-E 11 Bay Mid Tower Case with Front USB & 450W PSU
http://3btech.net/b8211midtoca.html
All together I come out pretty close. I'm open to any suggestions if you have seen a better deal somewhere else. Keep in mind, I don't want to go over $200 that much.
Thanks
Well its gonne have standard A-XP 2000+ power and if that is enough well....
What will he/she use it for?
There is no possibility to work with graphics on that machine but for office use it sure beats the crap out of my machine at the office....
Basic school work. He lives on my school's campus. But basically writing papers and the sort. Nothing to do with graphics. Thanks for your input
the axp 2000+ is 1.66ghz, not 1.5.. i believe 1.5 was ~1600 or so
itll be fine for office papers, no doubt
What do you guys think of the Motherboard? Is Biostar any good? I don't want to have any issues with processor speeds being incorrect. Also, yea, the Athlon XP 2000+ runs at 1.67ghz.
from what ive heard, biostar is fine, certainly better than PCCHIPS. i think if the processor and board come as a set, there def wont be any speed worries.
Ok, thanks. I was thinking along the same lines, just wasn't positive because I have seen a lot of Biostar motherboards at Tigerdirect.com.
whats your point?
Sorry for the vagueness...
My point was that I was not sure if Biostar was a good brand. I remembered seeing the name around, but I saw it listed next to really cheap manufacturers as well. But thanks for your views.
