Need some custom fan grills
Penguincomp
Racer [H]
I need some custom 120mm fan grills made. Anyone know of a place that does that kind of work?
PC Mod Shop used to do that, but it seems they've scaled back their operations quite a bit, just recently.
You might contact them via e-mail, and ask about it. Seems to me that they likely still have the equipment to make a custom cut grill, and could do it for you.
Good luck! :)
I believe mpcamer1220 is referring to bonzanego... which is where I would point you to also. That guy can do amazing stuff, and doesn't charge the earth either
Bonzai Mods
