Hey fellas, I'm a first time poster... needed some advice, and a friend pointed me here and said the kind folks would assist.
Anyways, to the scenario. I've got 550 dollars to spend on a new computer, and I'm stripping all the external parts from my current (monitor, keyboard, mouse, etc.) as well as the hard drive. In all simplicity, all I need is a new Motherboard, Tower, Processer, Fan, RAM, and video card.
So, my first idea was to get the following...:
http://www.tigerdirect.com/applicat...s.asp?EdpNo=623825&Sku=S450-4100 R&CatId=1218
The Mobo details for those who don't feel like clicking:
Soyo SY-KT600 DRAGON PLUS
The magnificent SY-KT600 DRAGON Ultra Socket A Motherboard is an impressive board that boasts a high level of flexibility, offering AMD Athlon and Duron microprocessor support.
- Via KT600 Chipset
- Supports AMD Athlon XP processors up to 3200+
- 400MHz Front Side Bus
- 3 DIMM Sockets/Supports 3GB
of PC3200 DDR 400 Memory
-IDE and SATA Controllers
As for the processor, I haven't really chosen one yet. But a friend suggested that I get an Athlon 2400+ and overclock it. However, someone else says that an Athlon won't be compatable with the mobo. So, I'm in a rut.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=520706
For RAM... pretty expensive for 256, but a friend says it's good. Now, my question for this, is... is it better to have a powerful 256, or a high amount of mediocre ram?
For video card, I'll probably get a Radeon 9600 Pro. Unless I'm suggested to get something else, of course.
So, my questions are:
Will an Athlon 2400+ work with that Motherboard, or am I better off getting something else?
Is it better to have a lower amount of high performance RAM, or strictly more RAM?
Is there a better videocard I should get?
Any help would be greatly appreciated... and if someone can point me to the describes parts that are compatable and total up to under 550, I'd be very very thankful.
Regards,
DarkLich
- Via KT600 Chipset
Regards,
DarkLich
