- Jun 6, 2005
I need to do some mods on my PC and need some parts. I''ve never modded before so I don't know proper names of any accessories or good places to get cheap parts. So here goes.
I need:
Thin foam padding to line the inside of the case. Hopefully to kill vibration and damper the noise level a bit. (A recommendation for a better substitute is welcomed). I would also lke it to look nice and be able to cover any exposed wiring. Also, is it safe to lay this behind the motherboard on the motherboard tray?
Wire sleeving. Preferably a color that would stand out, but not look messy.
Rubber washers? Something to put between the fans and the case on the screws to elimnate vibration against the case.
A cheap PSU to replace the crappy Raidmax. Something preferably with those FlexForce cables, they look nicer and are more durable.
Clip in SATA cable. Maybe even a right angle one so I can turn my drive around.
Cheap 120mm fans with good ai flow and that are pretty quiet at low RPM.
Thanks guys for helping out a Modding newb. I hope to be a [H] Modder one day.
I need:
