Need Some Case Advice
I'm looking for advice on the best case to get with these features:
Minimum of 3 external 5.25" drive bays (4 is preferred)
At least 1 internal 3.5" drive bay (only 1 is preferred)
MicroATX form factor
Small size and weight
I was looking at the Lian-Li PC-A59B but it seems as if Newegg is all out of stock.
Antec 300 does look really nice. I'll keep that as a possibility, but it's a little bit larger than I had hoped for. I'm trying to find the smallest case possible. It will be tucked away in a corner of the room relegated fro small file server duties. But that case definitely has the specs I'm looking for.
