Need some advice....
Edeka
Here is my newegg wishlist.
http://secure.newegg.com/NewVersion/WishList/WishShareShow.asp?ID=1485896&WishListTitle=My PC
The only thing I have changed is I am going to buy the 3700+ at Zipzoomfly for $278.
Is there anything you guys think I need to change? Any cables I will need to purchase?
Somethings I am iffy on:
Whether the PSU has enough power for the system
If my Hard-drive comes with the needed SATA cable
P.S. I don't want to upgrade anything to make it quite a bit more expensive. I can't go much higher than it is now, as parents are paying for half of it.
I just realized this is the wrong forum for this. Please delete if needed, or just keep posting here. :)
Sorry for all the bumps, but I want to order this ASAP so I need some quick advice.
Going to bed, hopefully there will be some replies in the morning.
Isn't this a double post? Anyway I can't get to your wishlist and like I said over there the SATA cables will come with the motherboard.
Yea... sorry I realized I posted this in the wrong forum after I did it. If it needs to be deleted, go ahead and do it.
Also, I fixed the link in both my posts.
