Ok here is what I have going on.
Antec Twelve Hundred Black Steel ATX Full Tower Computer Case
ASUS P6T Deluxe V2 LGA 1366 Intel X58 ATX Intel Motherboard
Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor
12 Gigs G.SKILL DDR3 1600 Triple Channel Memory
Feser X-Changer Dual 240mm Extreme Performance Radiator
HEATKILLER® CPU Rev3.0 1366 Waterblock
2 Thermaltake A2018 120mm Blue LED Case Fans (For the Radiator) I had them laying around the house.
XSPC Dual Bay Reservoir Pump 750 lph
Feser Tube - FT - Active UV Hose - ID 1/2"
Shin-Etsu G751 Thermal Grease
Now my first question is this may sound a bit stupid but I'm a nobb when It comes to water cooling my very first set up here. I have the inlet from the res / pump running to the bottom fitting on the Heatkiller , outlet from res / pump to the rad then rad to the top fitting on the Heatkiller. Is that the correct way the loop should be?
The XSPC Dual Bay Reservoir Pump is in the bottom bay of my case , should I move it up higher?
I just added the XSPC Dual Bay Reservoir Pump and the 1/2 ID hose and fittings, before I was running the Thermaltake BigWater 760is 2U Drive Bay Water Cooling System with everything above with 3/8 ID hose and fittings my temps were 29-34 deg c Idle and on 100% load 70 deg c was the higest on all of the 4 cores.. now my temps are 33-39 Idle and Highest core reached 75 deg c on 100% load. Is that b/c I'm not using the extra rad that was on the Thermaltake BigWater (A piece of junk I know made a mistake getting that) But I learned from that mistake now I have a $165 boat anchor.
Here is my latest Overclock ,
CPU Ratio Setting - 20.0:
BCLK Frequency - 200(MHz)
Intel Speed Step - Disabled:
DRAM Frequency - 1604: CAS Tim 8-8-8 21
CPU Voltage - 1.35V:
CPU PLL Voltage - 1.88V:
QPI/DRAM Voltage - 1.35V:
DRAM Bus Voltage - 1.66V:
CPU Differential Amplitude 800mV:
Tested with Prime 95 and Intel's BurnTest V2
http://www.imageput.com/hosted/197742009-07-0114-47-25.439.jpg
http://www.imageput.com/hosted/58892009-07-0114-48-37.140.jpg
http://www.imageput.com/hosted/53689pm95temp.jpg
http://www.imageput.com/hosted/17140cpupm95sensor.jpg
Thanks for any help ya all give.
